Convert mm.CE to mm.H2O
Hello everyone,
I have any question.I don't know about unit mmCE.Can someone help me with converting unit of static pressure from mm.CE to mm.H2O.
Thank you for every suggestion.
RE: Convert mm.CE to mm.H2O
Per this website, 1mmH2O = 1mmCE.  I don't know what the CE stands for though.
From this site http://www.unc.edu/~rowlett/units/dictC.html
CE is French abbreviation for colonne d'eau, water column, seen in pressure measurements.
RobHend
"You should always have fun doing your job, if not then it is time to find something fun to do for a job"
