estimating vapor pressure of ternary mixtures
I need to estimate the pressure needed to keep a ternary solution from boiling as temperature is increased. The solvent is 25% DMSO in 3N KOH. Where can I find appropriate tables and equations to determine the natural boiling point of this mixture and more importantly the external pressure needed to keep this solution from boiling as the temperature is increased from 130C to 200C.
