Plugging of sulphur condenser tubes
I want to plug several tubes in a sulphur condenser but don't want to seal weld the plugs. Does anyone have experience with this? Any advice re potential problems with this method? Is there a standard length that the plug should be? What kind of fit is required? The tubes are 1 1/4" OD x 12 BWG thk. Operating conditions are as follows:-
Service - shell side - boiler feed water and steam
tube side - process gas and sulphur
pressure - shell side - 4 bar ga
tube side - 0.32 bar ga
temparature - shell side - 150 deg C
tube side - 320 deg C (hot end) to 164 deg C (cold end)
RE: Plugging of sulphur condenser tubes
The mechanical pop-plugs are less likely to damage things that one piece drive plugs. There are two piece drive plugs also.
Remember to plug both ends, but the discharge end needs a small vent hole for pressure equalization.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
http://www.torq-n-seal.com/index.html
This is a plug that we use a lot of as it allows one to plug both ends of an exchanger from one end. You can rent the equipment.
http://www.expansionseal.com/html/hepg1.htm
If you want to save the tube hole the pin and ring is the way to go. We eliminate the tube pressurizing by making sure the tube is ruptured before the final plug is installed
I agree about tube venting Syd, but in many cases people are plugging tubes for temperature control or other flow related reasons, and the tubes are intact.
Rust never sleeps
Both the tubes and tubesheets are carbon steel. The plugs are not to be pulled out and the tubes are not to be re-used. In fact, the condenser is to be replaced within the next year.
The torq-n-seal has promise for future use, however, I can't open the expansionseal link. Will try again.
Thanks all for the info.
Look at the Pop-A-Plug
