signal builder block
hi
    i  have a pulse which switches on and off at a certain frequency and i have a custom signal in the signal builder block whicj I want to trigger by using the pulse. is there any method by which I can do that.
RE: signal builder block
agein,
Try a switch..
I am guessing that the pulse is 0 or 1 so you can have the switch pass 0, input 1, unless threshold, input 2, = 1 then pass signal generator output, input 3.
inputs are labeled 1 to 3 from top to bottom on the block... else you can open itand read the help info in it.
hope this helps
BSK
