thrust and drag software for rotors
does any one know or any simple software or programs that can give total  rotor thrust and rotational drag resultant for given rotor dimentions
RE: thrust and drag software for rotors
Try googling     XROTOR
It might be a cousin of XFOIL.
I have never been able to get it to work because I get "Windows cannot open this file"
If you get it opened can you tell us how you did it.
Good Luck
I think it only runs in Unix, since it uses X windows. Contact Mark Drela at MIT
Cheers
Greg Locock
i also couldnt get it working
XROTOR works fine under WinXP.  Maybe you should try START > RUN > "CMD" and execute from the command shell.
Now, if someone would only write a decent man page for it, they'd really have something - I keep discovering new things about it all the time.
Brad
About Xrotor,
Thanks to AminG for giving the site adress.
Have you some information about Xrotor user guide ?
Paul
Hello Paul,
Drop an email to me (AminG@adelphia.net) - I might have some stuff for you regarding Xrotor
There is also a program called PropSim - useful for water propeller designs but maybe for other fluids also.
Google the following text to find it
"propsim is an easy to use"
