Unhide Hidden Paramters
I have a model that was delivered from a customer and some parameters are hidden in the tree and locked which I need to modify. Is there a quick way that I can just unhide all parameters in the tree?
RE: Unhide Hidden Paramters
-Hora
Go to Tools -> Options -> Infrastructure -> Product Structure -> Tree Customization.
You will find a list box with several things listed, among them "parameters". Make sure it's set to "yes". (not sure why it isn't just a check box - ???)
Hope that helps.
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
If you have the master file; then you can change the parameter there.
If you don't have the master file; then you can isolate the External Reference set, to delete all the links.
Derek
