A smiple Problem
A smiple Problem
I have a piece of steel in the shape of the disk. 10" diameter .25" thick. I need to drill 7/64's holes into the side of the disk. I punched indentions where I needed. The holes I drilled on the flat side of the steel worked fine. However as soon as I tried the curved side holes, I had a problem.
The drill bit will not engage. It simply rides on the surface.
I tried a drill press at each speed and then tried a hand drill. I used cutting oil.
Is there any way to make the drill bit go in?
RE: A smiple Problem
I thought that maybe the center punch hardened the steel at that precise point. So I took my dremel and ground off the indentation flush. That didn't help much. It speeded up the initial penetration on the flat side but not on the round side.
Don
Kansas City
Griffy
Thanks For everyones Advice.
Ken
