Safe isolation procedure
We have an industry recognised safe isolation procedure in the UK for circuits up to 400v. It requires that a test lamp is prooved on a known live source, isolate the circuit, proove the circuit dead with the test lamp, re-proove the test lamp. Lock off as required and place appropriate notices.
I am interested in such safe isolation procedures in other countries.
RE: Safe isolation procedure
(b)(2)(iv) Verification of deenergized condition. The requirements of this paragraph shall be met before any circuits or equipment can be considered and worked as deenergized.
(b)(2)(iv)(A) A qualified person shall operate the equipment operating controls or otherwise verify that the equipment cannot be restarted.
(b)(2)(iv)(B) A qualified person shall use test equipment to test the circuit elements and electrical parts of equipment to which employees will be exposed and shall verify that the circuit elements and equipment parts are deenergized. The test shall also determine if any energized condition exists as a result of inadvertently induced voltage or unrelated voltage backfeed even though specific parts of the circuit have been deenergized and presumed to be safe. If the circuit to be tested is over 600 volts, nominal, the test equipment shall be checked for proper operation immediately after this test.
The use of the word "shall" means mandatory. §1910.269 generally addresses conditions in an electric-utility setting. The cited text does not specifically call for testing of the voltage-detecting device before use, and only seems to mandate testing after use for circuits over 600 volts. I, and most others I know would never trust electrical safety to an immediate before-and-after verification. Similarly, corresponding §1910.147 lockout/tagout [LOTO] rules apply.
