ASTM D2729 Drain Pipe
Can someone tell me if this spec also covers the orientation of the perforations when the pipe is used for drain purposes?
We have a situation where a foundation drain is being installed.  The arch/structural/civil, whomever has specified ASTM D2729.  The submitials show the perfs down, and the spec says to install them up.  Not looking for a debate on which way people think they should go, just wether there is any backup in the spec.
Thank you.
RE: ASTM D2729 Drain Pipe
The ASTM spec only covers requirements and test methods for materials, dimensions, workmanship, chemical resistance, and joint tightness for the pipe - it doesn't specify installation methods.
Thank you, that is what I wanted to know.
Since the submittal indicated 2 row pattern conforms to ASTM D2729 , I was not sure.  I had a feeling that was the case though.
