Modelling an S.M.A in ANSYS
I am currently doing my 3rd year project as paert of Masters degree and it involves modeeling an S.M.A (SHape Memory Alloy) in ANSYS but I have a problem.  I am modelling a simple component and applying a force to it that should (and indeed DOES) take the material past its yield point, and the force obviously displaces the component.  I then want to apply a new displacement to the component from its newly displaced postion.  My problem is that when I remove the original force the componet springs right back to its original postion, when it should stay displaced (or at least partially displaced). I have tried a number of methods including using the FCUM command and also using Re-Starts and Load Steps but to no avail.  Any help will be greatly appreciated.  Thank you very much.
RE: Modelling an S.M.A in ANSYS
It sounds like you're running your analysis as a linear one. Try using substeps as in a non-linear analysis.
You should have a look in this Proceeding of the Internationa Conference:
"Thermal Modelling of Shape-Memory Alloy Fixator for Minimal-Access Surgery" : C. Song, T.G. Frank, P.A. Campbell and A. Cuschieri (Material Science Forum Vols. 394-395 (2002) pp.53-56; 2002 Trans Tech Publications, Switzeland).
Good luck.
Tawada
