Designing Foundation
Hi, I would like to ask you a general question about the designig of a foundation. I am from germany and i am doing for the first time a statik calculation accordnig to AISC, that is why i need a little help.
My job is to give the foundation loads to another eng. firm which will do the calculating of the concrete foundations. But i don't know if i have to use the security factor for Earthquake (Omega) in the load cases. Normally for the designing of connections we should use it. But i am not sure if it is right for foundations too. Or perhaps i should use it just for the dimensioning of the anchoring rods?
I'll be very gratefull if you can help me. Some links could be helpfull too.
Thanks in advance! Bye
RE: Designing Foundation
I woud post this in the Structural foum to get better responce.
forum256
post your question at the foundation engineering forum (see link above) and do a search, I believe this has been discussed in the past
