V5 missing toolbar.
V5 missing toolbar.
V5 missing toolbar.
I am trying to add material to my part and I'm missing my 'apply material' toolbar. I tried the restore positions and restore content, it is on and I even restarted Catia and I turned all other toolbars off exept that one, no luck. I checked to see if the 'apply material' command was still on that toolbar, it is and so I'm stumped.
Anybody ever have this problem and if so, how do I get it back?
RE: V5 missing toolbar.
exit catia and delete catsettings... search forum for more info about that if you need.
Eric N.
Hmmm - which workbench are you in?
If you turn on the Apply Material toolbar, I'm not sure why you can't see  it.
Another way to do it is use the Power Input and type in "c:apply material" (no quotes)
Or customize your toolbars and add the command to another toolbar
Are you sure that there is not a chevron on the right bottom side of your screen, apply material toolbar maybe hidden.
greetings
Hey all!
Thnx for the replies. First, deleted all the file in CATSettings, restarted Catia and still the same problem.
Second, I'm in the Part Design work bench.
Third, no chevron. I closed all the toolbars except the apply materials toolbars and still could not see it. It wasn't hiding anywhere that i could see and when I checked to see if the apply materials command icon was on the apply materials toolbar, it is. I don't get it. I did put the icon on a toolbar I created so I can use it fine just puzzled on where it could've gone to.
Again, thnx for the help guys, I appreciate it!
