Edit Setpoint group 2
I have a question  regarding SR750. Can we edit Setpoint group 2 on Enervista software?
RE: Edit Setpoint group 2
Yes. All setpoint groups can be edited.  Take care to program the input that changes setpoint groups.
My Enervista just got trashed when IT gave me a new computer, otherwise I would look up nad tell you how to do it.  I recall that you need to select the group or enable it in a configuration menu soemwhere.
good luck!
You go to the screen where you set the active setpoint group.  One of the fields is the edit setpoints group.
If the edit group is not the same as the active group, its LED will flash on the front panel.
