Treatment of industrial wastes
I want to arrive at a convenient method, to treat liquid waste from a petrochemical plant. My main aim would be to reduce the BOD, TSS,TN, and TP content of the waste stream down to acceptable levels before discharge into the public system.
Design capacity ought to be around 10 million cubic ,meters per year.
How do I go about solving this one?
RE: Treatment of industrial wastes
If so, Your only practical alternative is biological treatment, e.g., an activated sludge system.
If you post details, I will try to help.
5.5 million GPD sounds about correct.
Why activated sludge though? Any particular reason?
Basic objective would be to neutralize and/or reduce the hazardous characteristics of the influent stream as characterized below, before discharge into the public domain
Information at hand:
Process: Unit & Source (Tonnes/yr)
Basic (Tonnes) TSS BOD TN Oil
Industry
__________________________________________________________
Ammonia 2x10^6 - 5873 1468 161515
Methanol 1x10^6 - 44383 - 12105
Chlro- Alkali 2376 1 - - -
Urea 53x10^4 53 - - -
Urea Resins 5940 1 1 - -
Lime 49500 - - - -
___________________________________________________________
Electric arc 65x10^4 4140 9514 - -
Secondary 165 <1 <1 - <1
Aluminium
Natural gas 0.62x10^6 - - - -
Electric arc
furnace Unit & Inorganic Putrscible
Source solids solid
(tonnes) (tonnes/yr)
65x10^4 5753 -
I will have to review your data. Maybe you could look into equalization initially. Combine the discharges. Maybe there is a dilution. If the regulatory agencies allow that. But my first guess was the AS because of the large flow rate.
I'll try to reply soon.
Are the wastewater streams fairly continuous? Look at equalizing the wastestreams, calculate the concentrations and loads in the final combined discharged. That may meet your acceptable limits.
V
Just a thought.
saxon
Electrolytic treatment with subsurface aeration using membrane diffusers would reduce or eleiminate 90% of this. The treatment area would be small, and be vastly superior.
Talk with Rick Brust at Clear20 - 847-498-9817 - he can lead in the right direction.
Dave Orlebeke/Aquatic Technologies
