Call Access form procedure from Excel form
I'm having a bit of a problem calling an procedure on a
Microsoft Access Form from an Excel Form. I've created the
Access object, opened the database containing the form,
displayed the form, autofilled some textboxes, but I can't seem
to get the correct syntax to call one of the access form's
procedures. This is what I have so far:
I have an Access form called InputData
It has a textbox called txtData
From within an Excel form I have this code:
Dim appAccess As Object 'Microsoft Access database object
'Create an instance of Microsoft Access
Set appAccess = CreateObject("Access.Application")
With appAccess
   'Open the database "ABC.mdb"
   .OpenCurrentDatabase "C:\My Documents\ABC.mdb"
   'Open the "InputData" form.
   .DoCmd.OpenForm "InputData"
   .Forms![InputData]!txtData.SetFocus
   .Forms![InputData]!txtData.Text = "Demo Data"
   'Call Procedure "StoreData" on Access Form "InputData"
   HELP!
End With
RE: Call Access form procedure from Excel form
Assuming that the StoreData() procedure is invoked using a command button (if not, add a command button, give it a name, have it call the form's procedure - you can set the button to Visible=No if you want)...
Them inside your with loop:
  .Forms![InputData]!cmdMyButton.Click()
That should work.
I am also having a problem calling a procedure from excel
Private Sub CommandButton1_Click()
Dim en As String
Dim r As Integer
Dim c As Integer
Set myrange = Range("A10:A60")
'Open the database "RDS.mdb"
appAccess.OpenCurrentDatabase "M:\rds.mdb"
'Open the "ESU form" form.
appAccess.docmd.OpenForm "ESU form"
appAccess.Forms![ESU form]!txtEN.SetFocus
r = 1
c = 1
For r = r To 50
en = myrange.Cells(r, c)
If en = "" Then
r = "50"
Else
appAccess.Forms![ESU form]!txtEN = en
appAccess.Forms![ESU form]!cmdMyButton.Click()
End If
Next r
'close access
appAccess.Application.Quit acEXIT
Set appAccess = Nothing
End Sub
AFTER I entered  appAccess.Forms![ESU form]!cmdMyButton.Click() I get a compiler error expected =
I am new with VBA please help if I use = true then I get a runtime error 2465
please help
Todd
