Shaft with key and sleeve - Torsional Loading Simulation
I want to simulate the pump shaft,key and sleeve as an assembly to check for strength. The assembly is loaded with torsion and downthrust (axial load along the shaft axis)
I am defining contact between shaft & key, key & sleeve, etc.
My question is what boundary condition should i apply and where to apply on the parts ?
Please help.
Please help.
RE: Shaft with key and sleeve - Torsional Loading Simulation
