Description-SW Explorer or Windows Explorer
Is there a way to display "descriptions" in SW Explorer or Windows Explorer? I RMB on the windows toolbar and added "descriptions", but it doesn't disply the SW description. And I could not find any options in SW Explorer.
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: Description-SW Explorer or Windows Explorer
I believe it only displays the Summary information. Not the Custom or Config Specific properties.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
I have not found a way. I probably wouldn't use it anyway because PDMWorks displays the info I need.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Hi Chris,
I'm stuck with the poors PDM. It's called SW Explorer!
}clown
Macduff spin
Colin Fitzpatrick
Turning on "comments" in Win Exp will show some info.
Chris
AutoCAD 06
SW Explorer shows both Custom & Config Specific Descriptions. Are you looking for some other type of Description property?
cheers
CorBlimeyLimey,
I saw that in SW Explorer, but looking for it next to the parts, drawings and assembly in the command mager in SW Explorer.
Macduff spin
Colin Fitzpatrick
macduff
What I do is add information in the Summary as suggested by CBL.  I then updated the Windows Explorer display and the information from the Summary section will appear.  Some of the information that I use is the Author (Designer's Initials) and Title (Description).  I find this easier to find a Model or Drawing that I required.  Hope this helps.  Cheers.
Cheers,
Ralph Wright, CSWP
SolidWorks 2005, SP5.0
P4, 2.53Ghz
1.5 Gb RAM
ATI Fire GL8800 Card
Windows 2000 Pro
macduff ... you mean like the View > Tree Display function in the Feature Manager.
Sounds like a good Enhancement Request.
cheers
CorBlimeyLimey,
Exactly! But want to do the same thing in SW Explorer.
Macduff spin
Colin Fitzpatrick
