Spherical mate along curve?
So.. I have this ball in an assembly, and I want to have it roll between two steel plates that are equidistant from each other, both with an identical curve (imagine a piece of U-channel that is curved with a steel ball rolling along it).
Is this possible to model in SW to the point of animation? Is there some special mate I'm missing that would work well, like maybe the cam mate in some way?
I saw something similar on Mike Wilson's site, but I'm not sure how to implement it for this particular application.
h ttp://www. mikejwilso n.com/soli dworks/sol idworks_fi les-06.htm
Thanks!
h
Thanks!
RE: Spherical mate along curve?
I ended up drawing a spline in the channel, mating it equal distances from either side. I then extruded the sketch to be a surface, which worked well when I mated the origin of the cam follower to the surface.
If it must roll, that will be more difficult. Perhaps use some features within SW 2007 to create a belt relationship with a path and the ball can roll along your path, also limited with a distance mate or mated to a curve/segment.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Thanks for the ideas so far...
Good luck.
Jeff Mowry
