auto update after design table change?
How can I get my part to do auto update after I change parameters using a design table? The sketch and part don't update unless I open and close the sketch in the Part Design workbench. Is there any way to just have it update in the assembly design workbench?
I've got my options set to auto update and "all the levels".
Pedro
Pedro
RE: auto update after design table change?
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
pedro
Perhaps I wasn't clear in my first post, but the design tables are linked to the constraints of a sketch which is used in a part body.
Appreciate the help.
Grab the design table, and any part associated with it. It helps if they are stored in the same directory, and you can sort them by location path.
This should occur regardless of which module you are in. Now if you are in assembly design the update icon should become active. If you are in an active CATpart and your design table affects a different part the update icon does not change, but the Knowledge report menu will still pop up indicating a change. Double pick on your top product to update the entire assembly.
Derek
You are not assigning the design table directly to the constraint - are you?
My part files do not prompt an update in the assembly if I am working at the part file level. When I am in the assembly and make the change, yes. I even, occassionally, have trouble with the session data being "stuck", forcing me to close Catia to get an update.
I usually solve the problem through Edit -> Links, but apparently decsonstructor is not having any luck with that method.
I had the same experience, after you make changes in the design table you must open the part, update it and save... there is no other way.
Damir
