Resistor for RC Network
I am looking for a wire wound resistor for an RC network with the following specs:
50 ohms, 60 or 70 thousand Joules, and 75kV withstand
Does anyone know of a company that I could get this from?
Be Safe.
RE: Resistor for RC Network
Try someone like Cressall Resistors, or maybe Eaton if they are still in this ;ine of business. Is this for a traction application?
  Sometimes I only open my mouth to swap feet...
No, this filter is for the secondary of a 34.5KV to 4160V XFMR which is feeding switchgear.
Thanks for the help
Be Safe.
Cressall are definitely where I would look in the UK - I think Eaton and Cressall were competing for the same market, so they split the market into utility resistors (Cressall) and traction resistors (Eaton).
TPR are another UK-based industrial resistor manufacturer. Depends where you are in the world - any of the companies who build neutral earthing resistors should be able to help you out.
Im in the US.
Be Safe.
