Modifying an existing clarifier
I am having to check an existing clarifier to see if we can add one foot of depth. I have the existing drawings (from 1969), so I have the geometry and the reinforcing. I do not have the design compressive strength, however, nor do I know the grade of rebar.
I plan to design a 9 ft clarifier, assuming 3 & 40 ksi (I know it's probably at least 4 ksi, but I can't be positive), and compare it to the 8 ft clarifier that is there. Hopefully, it is still good, and all I have to worry about is detailing the wall addition. My questions (to start with) are:
1. Were the environmental structures requirements (ACI 350) sufficiently similar 30+ years ago to what they are today? If not, how does one treat a conflict?
2. Has anyone performed a similar design? What can you recommend, and what should I be looking out for? I know one foot does not seem like a lot, but. . . .
RE: Modifying an existing clarifier
www.SlideRuleEra.net
