4000g assembly
4000g assembly
I'm working to design a small (~8mm cube, <12grams) electronics package and assembly that can live in an environment with vibration producing accelerations up to 4000g.
Does anyone know if anything like this have ever been done before? The most robust assembly I've found is munitions guidance systems package, but they're not built for fatigue, and helpful details have been hard to find.
I would appreciate any other tips (ranging from preferred IC connection, to robust solder compounds, potting, PWB materials, and anything else) on how to keep this from falling apart.
MB
MB
RE: 4000g assembly
Here is some reference material:
www.stiweb.com
www.skfcm.com
www.bently.com
www.compsys.com
www.entek.com
Other references include app. notes and vibration analysis books on www.reliabilitydirect.com, ; and http:
If you have specific questions then maybe we can give you specific answers.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: 4000g assembly
Do you have any advice on bonding components under this loading so that they don't pop off the board?
Do you have any advice on supporting the board so it doesn't flex beyond it's limits?
RE: 4000g assembly
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
RE: 4000g assembly
Keith Cress
