Copy and Layer Mgt. Help
I am using CAD 2005 for 2D civil drawings and have the following questions:
1. When working in model space inside a viewport sometimes I am unable to use the copy and paste command. It appears to work, but when I pick the insertion point nothing shows up. To solve the problem, I have to go to model space (outside the viewport). This problem does not happen all of the time.
2. As I add layers, my model space view is getting very busy. What is the best way to manage this? I can turn the layers that I don't need off in viewports but have them all in the model space tab. I can turn the layer off completly at the model space tab, but then it also disappears from the viewport.
Thank you for the help.
RE: Copy and Layer Mgt. Help
2. You can create layer filters in the LAYER dialog to turn on/off layers by "groups"
"Everybody is ignorant, only on different subjects." — Will Rogers
