Swivel joint design
Swivel joint design
Hi
I suspend large metal objects ready for spray painting from a beam using chains, S-hooks and U bolts. The #1 problem is that the painter has to move around the object during spraying, instead of being able to rotate the object around on one axis. Problem #2: the joint must be able to take heavy loads (100 kg +) and problem #3 the joint must tolerate foreign material such as metal dust, overspray and shock. Any tips about designing and making a simple swivel joint - apart from going to buy one?
Much Appreciated.
Much Appreciated.
RE: Swivel joint design
ht
Naresuan University
Phitsanulok
Thailand
Artisi - salvaged wheel bearing + parts + clevis pin + 2 x 5mm flat plate = swivel joint. Interesting, I'll give it a try. My two other bearing designs failed due to contamination and stess.
Thanks.
No offence taken. I know about the liability of workplace accidents, but I'm going to make one anyway just to try out myself. The production joint is going to come from a local engineering firm that uses the joint in truck engine hoists.
Go to the "Vanoil Equipment Inc" website and take a look through their online catalog. You can see various layouts for Knuckle Joints, pick one and customize it for your own personal use.
This is not a complicated thing, have buddy run a few stress computations for you to ensure strengths.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
