Load Pin Material
Load Pin Material
I am looking for the best possible material for load pins. Currently, I am thinking of using 17-4 PH SS heat treated to H900. Is there something available that has similar yield strength (~200,000 psi), but with better Charpy Impact resistance values?
RE: Load Pin Material
Type 17-4 PH
http://cartech.ides.com/datasheet.aspx?E=261
AerMetĀ® 100
http://cartech.ides.com/datasheet.aspx?&E=161
MP35N
http://cartech.ides.com/datasheet.aspx?E=3
Alloy 725
http:/
General information on high strength fastener materials
ht
low at subzero temperatures; consequently, the use of 17-4PH for critical applications at low temperatures
should be avoided."
Do you have much experience with Custom 465? I've been doing some research and the properties are excellent, very much what I am looking for? Any drawbacks or unusual properties that I would need to be aware of?
Are there any corrosion issues? What temperature range?
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
