locating a hole
locating a hole
locating a hole
I've extruded a cylinder around the origin & want to place a threaded hole at the origin. If I try to use the hole wizard it won't let me place the hole there. What's the easiest way to do that?
RE: locating a hole
1) Click on a surface, close to but not at the position you want the hole to be.
2) Click on the Hole Wizard icon. A point will be placed where you clicked on the surface.
3) Select your hole type & size.
4) Select the Position and deselect the Point icon.
5) Drag the original point to the position you want the hole to be.
6) Click on the green tick.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
RE: locating a hole
Thanks - that works.
RE: locating a hole
is this hole going on the cylindrical surface or on the end surfaces?  Also, what version and SP of SWx are you using?  I remember running into some problems putting thread holes on cylindrical surfaces with relations to the origin.  Otherwise just follow CBL's instructions
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: locating a hole
CBL is right- the key is to pick the surface first, and then start the hole wizard.  that issue drove me nuts for a while.
