"Reload" Option in file menu not staying on
For some reason my machine won't let me customize my file menu to always shown the "Reload" option. If I check it on, and exit the customize menu selection, it turns itself off again. This happens in all parts and assemblies. Has anyone else experienced this?
RE: "Reload" Option in file menu not staying on
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I took it a bit further then resetting everything, just renamed the "Menu Customizations" subcatagory and reset that. Exported the new values, then customized Reload off and exported the resitry again. Found the key that seemed to be messed up.
I put my old Menu Customizations back and changed the value to one that worked and presto, instant fix.
Thanks again. :)
I put my old Menu Customizations back and changed the value to one that worked and presto, instant fix."
That's instant??????
