Pilot Operated Vs Direct Acting Pressure Reducing Valves
Anybody knows the typical droop for both? Want to know this as would like to know if I am presented with both options, whne should I pick either or?
Been readind thru books and they only give qualitative criterias and not quantitative.
Thanks.
Thanks.
RE: Pilot Operated Vs Direct Acting Pressure Reducing Valves
For direct acting valves, each manufacturer rates thier own valves, so there is no typical. In most cases, they have a different rated Cv's for the valve according to the amount of droop that is acceptable to the end user.
For example the valves I am familiar with are the Leslie GPK. for a 3" valve they report a Cv of 55.8 with 2 psi min. droop and a Cv of 84.6 for a 3.5 psi min. droop.
It is similar with Cashco direct acting where they report an entire chart of Cv's with 10%, 20%, and 30% droop.
I don't know if this helps...
