Edge beam on precast load bearing wall
Is it a good design practice to have edge reinforced concrete beam (say 900mm to 1000mm wide) supported on 150mm to 200mm thick precast load bearing wall running parallel to the beam? I mean the beam would be supported by the wall (like an inverted L shape) eccentrically on one side.
How would you detail the reinforcement so that load from the beam can be carried to the wall?
RE: Edge beam on precast load bearing wall
Hence the main rebar seems to be the transversal, atop, but I would detail it as a tie or beam, top and bottom plus stirrups.
Then any flexural effect passed to the wall needs be met in the precast part.
