Purpose built electromagnets drving motors?
The electromagnets have a 1,000 pound holding power and are round 3" purpose built electromagnets. Could they be used to provide strong rotary motion by pushing a permanent magnet?
RE: Purpose built electromagnets drving motors?
What is rotation angle?
The 1000lb is probably when the air gap between the pole to the plunger is zero. When the air gap is larger the force drops rapidly. To push the magnet the air gap (the distance between the electromagnet pole to the magnet will increase. This will result in a drastic result of the pushing force between the electromagnet and the magnet.
You should ask help from a professional.
It is better to design/buy s rotary electromagnet but it will be much larger.
If you design electromagnets to be used on alternating current and produce rotary motion, the optimum design often ends up looking like a motor.
There is more involved than just 1000lbs. force with zero air gap.
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
