Allowable deflection of pipe?
HI guys,
Anyone know how to consider allowable deflection of pipe? As I found, it seemed each engineering company have difference value of allowable deflection of pipe for design.
Dave
Dave
RE: Allowable deflection of pipe?
http
pipingdesigner
www.pipingdesigners.com
Norm
I typically work through the mechanics under full bore load (i.e. maximum pressure testing @ 1.5 MOP) and add the external loads as boundry conditions to the supports.
You can also get similar equations from API reference material. Try pipe supplier websites, they do provide spreadsheet services on the various API equations.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
http://www.eng-tips.com/viewthread.cfm?qid=152615
Edward L. Klein
Pipe Stress Engineer
Houston, Texas
"All the world is a Spring"
All opinions expressed here are my own and not my company's.
