How do you calculate the autoignition temperature of a gas mixture?
This was a topic in thread135-86198.
In this thread (the last post) a poster by the name of jcaiken said:
"One standard (can't remember which) identifies that the impact of gas components less than 10% by vol can be discounted but the overall AIT should then be based on the lowest component AIT."
Does anyone know which standard he/she is referring to?
Thanks in advance!!
RE: How do you calculate the autoignition temperature of a gas mixture?
I think they must have been determined experimentally back in antiquity.  I've been looking for a way to predict autoignition temp for 15 years through 100s of books and found quite a few tables (with a range of values for any given gas), but no equations.
David
Thank you for the response.
Is there a standard that says you are able to discount part of the mixture that make up less than 10% of the total?  Maybe a NFPA standard?
Here is little information that might help.
http://www.aristatek.com/newsletter/0606June/TechSpeak.aspx
This is form a PEAC-WMD software site but there is a tremendous amount of information out there on calculating autoignition temperatures.
Where is MB when you need him?
