Arcing through a nylon tube running natural gas
My issue is the concern of running natural gas through a nylon tubing instrumentation line. I'm concerned that a static charge may build up and cause arcing through the tube which would lead to an explosion. The pressure in the line is low, around 30-60 psi, with flow rates/velocities which are undetermined as of yet. The tubing is 1/4" ID with a wall thickness of .040".
Based on the dielectric strength of the nylon, it seems that a voltage of 14000 V will be enough to cause arcing.
Is there any way to measure the strength of the electric field, to get an idea of how high the voltage levels are? Is a maximum voltage that the tube could collect? (is there a way to determine that maximum?)
And is there any way to know the velocity above which conditions will be unsafe?
Any help in this matter is greatly appreciated.
RE: Arcing through a nylon tube running natural gas
Is it legal to pass NG through a nylon tube in your place of work?
Does nylon have the qualities required to resist any chemical attack that the gas may present?
Does nylon tube allow NG to pass through its walls? it wont stop helium.
A specialy developed plastics pipe is used in UK underground gas supplies which does resist any form of attack from the gas, I would suggest that you use a similar material and cover it if you wish with a metalic screen bonded to ground to prevent arcing from the outside of the tube.
From a chemical resistance standpoint, the nylon is compatible with NG.
would be, it may not damage the elastic nylon tube.
I used some unknown 6mm plastic tube for H2+O2 torch and it exploded back several times without any effect.
Why don't you try adding O2, and exploding it, to see what
if any damage an explosion would cause ?
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
