Pipe Support Blocks
Pipe Support Blocks
Need to copy a whole series of pipe support details from a pdf file into Autocad. Am looking for supports in block form, and have not had luck using key words. There must be a thread for autocad blocks.
RE: Pipe Support Blocks
I've just been drawing the supports as I need them and compiling a block library. I do the same for fittings.
h
"Everybody is ignorant, only on different subjects." — Will Rogers
