Possible to generate input file from CAE?
Is it possible to generate input files from CAE?  If so how?
Also I am using Matlab with Abaqus, I know how to run an input file in Matlab but I do not know how to view the results, except for manually going to  the directory and opening the file in Abaqus.
RE: Possible to generate input file from CAE?
CAE generates the input deck in the job module
corus
And in job module go to command "Write Input"
@ohagan : How do you run ABAQUS job in matlab ? Do you use the DOS command ?
doubleje, I am using the following command to run abaqus in matlab, (windows system):
!abaqus job=jobname interactive
where jobname is the name of the input file without the file extension
We have to put the "!" before the same command in MS-DOS (cmd/command) to run ABAQUS.
For  viewing the results, you can use :
CODE
!abaqus viewer database=path/jobname.odb
For exemple :
CODE
!abaqus viewer database=E:\ABAQUS\work\maer\meshca_maer.odb
It worked.
