Model Dimensions in Drawing Views--Far Away
New 2007 install--when I place drawing views, dimensions are often stretched far off the sheet. I have to zoom way out and drag them back in.
I recall something like that happening in 2006, and I thought I changed a setting that took care of it. However, I either remember incorrectly, or I can't find the setting.
Help? Thanks,
Brian
Help? Thanks,
Brian
RE: Model Dimensions in Drawing Views--Far Away
One of the common fixes from a VAR if you're experiencing something strange on your system not evident on other systems is to go into your registry and rename your SolidWorks keys to something else and restart SolidWorks, which will regenerate the keys "fresh". DON'T DO THIS UNLESS YOU KNOW WHAT YOU'RE DOING. I don't remember the details, so what I mentioned isn't complete--you have to pick the right keys (under HKEY CURRENT USER > SOFTWARE or something like that) or you'll hose your entire system.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
It's the system setting "Automatically place dimensions inserted from model." When on, it tries to arrange dimensions. When off, I believe that it uses sketch placement. It must be attempting to arrange based off of the sheet scale or something... whatever it's doing isn't pretty.
2006 did the same thing. For that matter, so did Mechanical Desktop back in the day.
Thanks for the response...
Brian
