HOW CAN I EXPORT A LINE LENGHT
Is there some way to extract to file, the a layer lines lenght?
RE: HOW CAN I EXPORT A LINE LENGHT
I dont know if this is what you are looking- type LI (listing) on command line; then press F2 for a history of the line; highligth the pertinent info; do a copy to clip board; do a paste on the file which you want the line length.
You can drag them in from design center or copy your *.lin file to wherever.
"Everybody is ignorant, only on different subjects." — Will Rogers
fokinniga,
I think you want to have the length inside an excel.xls. http://www.jtbworld.com/lisp/bomlenghts.htm
Then copy it into the *.xls.
That's more comfortable like "_list"
I don't know an automatically way. Search in the www and reply.
Lothar
ADT 2004
ACAD 2002
Thanks.. for your help...
