Is anyone using ATI's Radeon 9550 with Inventor
We have been using AutoCAD 2D for years and are now considering going to Inventor. I have A Radeon 9550 dual-monitor card in my system now and would prefer not to have to change as it works well with the Altium PCB software I use and AutoCAD 2004.
Is anyone using this video card? If so, what problems, if any, have you had.
Steve Smith
Steve Smith
RE: Is anyone using ATI's Radeon 9550 with Inventor
The old theory was ATI meant always trashes inventor...but the new drivers and some of the cards are doing pretty well from what I have read.
You should look at the autodesk site to see if the card has been "certified" for use with inventor before you count on trouble free usage. It will also depend on the size and complexity of your assemblies and the number of files you have open at one time.
Whether you need to upgrade depends greatly on what you demand of it. If you're just making small, simple parts, there's no need for anything fancy. If you're doing complex surfacing, or large assemblies, rendering time will increase, perhaps to an undesirable level.
