Need book or info on Miller/Atkinson Cycle engine
Can anyone recommend a good book or other source of info on the Miller Cycle engine? As I understand, it is simular to the Atkinson Cycle (less the complex mechanism) engine but with a pump to get the specific HP back up. Thanks
RE: Need book or info on Miller/Atkinson Cycle engine
http://en.wikipedia.org/wiki/Miller_cycle
http://en.wikipedia.org/wiki/Atkinson_Cycle
Miller cycling was first proposed in a 1947 Society of Automotive Engineers (SAE) paper by Ralph Miller. The title was "Supercharging and Internal Cooling Cycle for High Output".
Concerning the Atkinson cycle: There are several photos or drawings of Mr. Atkinson's engines in a book by Lyle Cummins called "Internal Fire". There is also a brief description of how it worked.
j2bprometheus
Heres some sites:
http://ww
http:/
http://millercycle.quickseek.com/
http://experts.about.com/e/a/at/Atkinson_cycle.htm
ht
Hope it all helps.
Thanks for the help. The Prius article had some hard valve timing and compression ratio data!
Ken
