Documentation
Documentation
My UK based company owns/operates a liquid CO2 system for fire fighting purposes. MAOP is 22 Barg. The liquid CO2 is distributed by various sizes of pipes the largest being 100mm to the different areas. We have no technical documentation on the pipework - no material certs, welding records, drawings, or CE certification. My understanding is that for a cat II system that this should all be supplied by the manufacturer - am I right in this? The supplier is no longer talking to us - do we have any legal recourse in this matter?
On a similar issue - is the system supplier required to carry out a hazard analysis and should this also be provided to the end user?
Alan
Alan
RE: Documentation
Unless spelled out in the Purchase Order or demanded by Code, it may be exceedingly difficult to obtain cooperation from a non cooperative supplier, especially if it costs money to provide.
http://www.welding-advisers.com/
RE: Documentation
2- if you do, are you violating any laws?
3- if you are, you are in trouble.
'see the law will get you first, then you seek damages from
the mfr if you can, else you are screwed.
genb
RE: Documentation
I think you can also contact the DTI directly, who may also be interested to hear about your system supplier.
