Converting to AutoCAD 3D
Has anyone the experience of getting a Solid Edge model (v18) into AutoCad 3D?? If so how/what software/translation did you use??
Many many thanks in advance
Simon
Simon
RE: Converting to AutoCAD 3D
Sat is don't know why they are having a pb opening the sat files you generate with SE.
In 'options' when saving as an SAT file, try changing the ACIS version to an older one (smaller number)
Fred
