Spring loaded piston Check valvee DP
Does anybody know what the pressure drop of "Spring loaded piston Check valve" is?
I could not find any number from Crane or Perry.
RE: Spring loaded piston Check valvee DP
They are spring loaded, axial flow piston type check valves with low pressure loss and non slam performance.
Check out www.noreva.de
Just to be sure: You're trying to find an average pressure drop for a specific type check valve to use in a calc rather than trying to find a source for said check valve?
I take it, you've already hunted down whatever original paperwork exists for the valve and it doesn't say? And you've contacted the manufacturer, assuming they're still in business? Or you've gone in the field and cleaned off the valve nameplate to check there?
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
I am desiging a circuit which includes spring loaded check valve. I like to know what is dp of this type check valve. I need this for pump sizing.
Thanks again.
tell me the flow rate and pipe size and I can calculate the dp for a Noreva valve.
Flow rate is 8.8 m3/hr and line is 2 inch.
Thanks again
a flanged 2" Noreva NRV-ZK valve will have a dp of only 9.7 mbar or 99 mmWC or 0.14 psi at 8.8 m³/h.
Excellent.
