Shell Expansion
Shell Expansion
Shell Expansion
Hello Users
I'm an Engineer and working with ACAD14.
I need a Lisp program for Shell Expansion.
Can you help me or give me more info for it?
Best Regards
Ramin Baratpour
raminb@yahoo.com
RE: Shell Expansion
Shell expansion can be performed on 2d or 3d entities using the "scale" command.  The center of the shell and amount of shape size change (factor) is needed.  AutoCAD R14 can use lisp but scripts and VBA are also available.
The expansion might be more complex than this however.  Are you trying to automate the drafting/modeling of expansion as a result of the application of loads?  Do you want the lisp routine to calculate the new shape and then draw it?  This could involve an outside routine that determines the new shape and exports its information to AutoCAD for redrawing.
Mike Van Voorhis
MJVanVoorhis@CS.com
RE: Shell Expansion
Dear Mike;
Thank you for your valuable reply, this is my first and maybe best answer.
Can you help me more, or do you have Lisp, Script or VBA for this purpose?
Thanx, Ramin
raminb@yahoo.com
