Create New Layer
Create New Layer
Why can't I create a new layer?
The dialog box is greyed out, what do I need to do to overcome this?
I learning solidworks from a book etc so all this is basic stuff
RE: Create New Layer
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 8/12/06)
SW 2006 SP 4.0 / SW 2007 SP 0.0
I can only create a layer in a 2D drawing not in a 3D sketch.
If I create a layer in the 2D drawing can I then switch it on and off in a 3D sketch?
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
Different from ACAD.
I second Wes's question, what exactly are you trying to accomplish?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Instead of using layers in a model, features can be shown or hidden, supressed or unsupressed using configurations. Specific feature types can also be assigned specific colours to help differentiate.
The original purpose was to be able to switch in and out centre lines.
A centre line I used in one sketch was not available in a new sketch, so I though if they were in one layer (centre lines that is) I could switch them in and out as required.
Also, if it's just hole or cylinder centrelines you need, you can use the View > Temporary Axes function ... or if you created Reference Axes, View > Axes.
