finding multi-section surface tool
My multi-section surface tool has dissappeared! I can't seem to locate it any longer. It doesn't seem to be buried anywhere. I found the multi-section solid tool but not the surface tool. Is there a command or a menu item to bring a tool to the front. I have other multi-section surfaces in my assembly which I can double click on to edit them but I can't make new ones.
There must be a very obvious solution to this but I can't seem to find it.
Help...
![[ponder] ponder](https://www.tipmaster.com/images/ponder.gif)
pedro
Help...
pedro
RE: finding multi-section surface tool
Or you could use Insert + Surfaces and click the Multi-sections Surface tool there.
