How do I create a real (not cosmetic) 3D screw/hole thread?
There were LISP programs in AutoCad that did this. Is there a way to incorporate this in SolidWorks?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: How do I create a real (not cosmetic) 3D screw/hole thread?
Create a helix on the surface of the hole.
Create a plane at the end of the helix.
Sketch the thread profile (removed portion) on the plane.
Use the Swept Cut tool to create the thread.
f you need the geometry for creating tools for casting or molding, then go ahead. If not, best to stick with cosmetic threads.
All it is a Cut-Sweep with a profile and a path (helx) it will cost you performance and can slow you down in your assemblies, etc. but i know some people have to have them. SO when your system gets slow, you can't complain, because you have been warened that helixs and complex geometry will slow systems downs. SW is not AutoCAD, SW requires highend machines where ACAD didn't need this... so hopefully your system is configured correctly to run with SW, or you will take a larger hit then you would if you where running certified equipment.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Dan
www.eltronresearch.com
