problems with make in cygwin
ok, I'm working on trying to get PalmOS code to compile, or more specifically, make under cygwin, and it's giving me an error message that I don't know what to do with:
Administrator@VAIO /MyProject
$ make
( cd GCC/; rm *.bin; pilrc -I ../Src/ ../Src/Resources.rcp)
rm: cannot remove `*.bin': No such file or directory
pilrc: not found
make: *** [GCC/bin.stamp] Error 127
any ideas?
RE: problems with make in cygwin
Hi belsonc!
The line you sent shows the following commands executed one after the other:
cd GCC/
rm *.bin
There is no *.bin files in GCC directory (probably just a warning output by rm function)
pilrc executable file is not found. Where is this executable? I don't know; you have to figure that out on your machine.
It seems the problem is not related to make, but to "pilrc" which is not found in the PATH environment variable.
