Magnetic properties (Steel)
I'm working on magnetic simulations by means of finite element method, and I've had problems to find magnetic properties on the web.
¿Do you know any website with data for different steel grades? At this moment I'm trying to find magnetic properties (Bsat, BH loop, etc.) for AISI 1215 steel.
Thank you in advance.
RE: Magnetic properties (Steel)
Would this be close enough to 1215 steel? thread340-129625
0.00 0.00
1.82 3.34
1.98 4.00
2.19 4.98
2.42 6.00
2.68 6.98
3.01 8.01
3.35 8.96
3.81 9.99
4.43 11.02
5.34 12.03
6.71 13.01
9.03 14.00
14.04 15.00
28.35 16.01
61.77 17.00
117.17 18.01
140.34 18.34
164.76 18.65
186.97 18.91
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
Thanks for the data. Can you provide the source?
Thanks.
Here is what I use for 1215, you can see it is not very different:
H (Oe) J (kG)
0.000 0.00
2.594 7.02
2.996 8.02
3.427 9.01
3.929 9.98
4.620 10.98
5.612 12.00
7.026 12.99
9.462 14.00
15.023 15.01
31.099 16.01
66.801 17.01
123.307 18.00
189.936 18.84
Both sets of data are fully annealed.
http://www.matweb.com/
you can check it, but for a specific steel you should come direct in contact with the supplier. Otherwise you cannot find a lot and reliable datas.
Matweb is indeed a good site, but it does not have BH data, which is what the OP requested.
