I-DEAS NX11 Slow
I-DEAS NX11 Slow
Hi everyone,
I need your help solving my problem. Maybe there is someone out there who experienced this issue. I've installed I-DEAS NX11 on HP Xw4200 workstation running on windows XP then the proccessing of I-deas is very slow like importing and exporting itself and even going to the library. The current configuration state below.
C:\UGSPLM - binary
C:\TEAM
C:\I-DEAS\Ideas-scratch - working directory
TDM at drive C -local
Hardware:
HP-Xw4200 -workstation
Pentium 4 3Ghz
1 Ghz memory
80GB SATA hardisk
ATI FireGL V5100 -video card
Please tell me what seems to be the problem on this.
Thank you
C:\UGSPLM - binary
C:\TEAM
Hardware:
Pentium 4 3Ghz
1 Ghz memory
80GB SATA hardisk
Thank you
RE: I-DEAS NX11 Slow
Ben Loosli
Sr IS Technologist
L-3 Communications
And since your TDM is local there should not be much to slow you down.
The only thing I can think of is have you got Team Compression on. By default it's off, if it's on then the data has to be uncompressed when you retrieve it.
What does Task Manager say about your CPU performance and Memory, is anyhting maxing out?
In the Task Manager once we do data in and out in the libraries the ideas shows not responding but of course we used of it so we will just wait until the data in or out. Then the usage seemed that the geomon.exe is taking more cpu usage.
Talking about the Team Compression where can I set this?
Tried that settings but no to avail same processing. Do you their is a hardware issue involved?
Tried that settings but no to avail, still the same processing. Do you think their is a hardware issue involved?
Are you sure you have a real performance issue rather than a perceived one? Are you able to do some timing comparissons for the same operations between your machine and another of a similar spec?
The XW4100 used AGP video Card and SCSI hardisk and the XW200 used PCI express video card and SATA hard disk.
