High speed bearing help. Sizing Question.
Where is a good source for high speed ceramic bearing (100,000 rpm). I found some sites but it seems like they only small sizes. Can you help me?
Thank you.
Thank you.
RE: High speed bearing help. Sizing Question.
They had a 115,000 rpm ceramic bearing when lightly loaded and using a oil lube not grease.
Check them out. I am sure that they are on the WEB somewhere.
Edson Campos
edsoncampos@earthlink.net
